Motor mount bracket/frame horns.
Andre LeMoine
- Round Rock, Tx
- 1985 CJ7. Stock as far as I can tell. 151 cui 4 cylinder, T-4 trans, Dana 300 transfer case, Dana 30 front, AMC 20 rear. Pro Comp shocks, urban camo.
Good evening everyone. Finally getting around to doing an engine swap on my '85 CJ7 . I acquired a AMC 258 i6 / 4.2l from a '77 J10 to rebuild and replace the stock Jeep 2.5l. Can someone steer me in the right direction as to which motor mount brackets I need to mount to the frame. Looks like from what I can tell the I6 mounts on the block are about 3'' farther forward than the 4 cylinder. I can see that the bump stop for the front axle will have to come off the frame. Has anyone done this swap on the late model CJ7 ? Right now I plan on keeping the stock T-4 Transmission if I can until I decide on heavy duty 4 speed or ax15. Thanks in advance for the help. Andre.
