Mystery locker
Mystery locker
BrockGrimes
Jeep-CJ.com Archive Master
Kathleen, GA
ON THE HUNT AGAIN
I have seen buttons like that in a wrangler. I have been searching my magazines to find where I saw them. They fit into the dash and look like they came from the factory.
The more I think about it I think the buttons are sold separate and may not indicate what lockers you have.
I would have a problem with the need to make a square hole.:cool:
The image above if just an example. Mine is red and says front locker.
There are wires running into the diff.
The switch I found says "front Air Locker". Yours doesn't have the word "air". I think its safe to say that switch is used for different types of lockers. If the seller or PO can't tell what diff you have I think you may have remove the cover. But even then?:confused:
Bought it from a dealer, yeah just "front locker" I know for sure it's electric as I see wires and a plug running into the diff.
Layout your opening. Masking tape works well. Drill out the corners. Connect the dots (holes) with a sabre saw. Square up the corners with a die grinder or file. Bingo rectangular hole!
How bad do you want to mount that switch?
Me personally?? not that much, way too much work. I like the safety cover switches, something like this. you know it's on or off.:cool: And they look cool.:D
Toggle Switch Safety Cover
$45.00
  22.5%
