Need a picture please.
crzylee
Brandon, Ms
1981 CJ-7
Ok guys I almost have everything put back together from my teardown. If I wouldn't keep forgetting screws and brackets at the house (45 min away from the jeep) I might have it finished by now :rolleyes:
Trying to put the throttle cable back on and can't remember how I took it off, can someone please take a picture of the way it is supposed to mount and what brackets are used, linkage etc. it would be most helpful!!!
Thanks guys and I hope to be able to post up some pictures soon!
I'll snap a pic when I get home if no one has posted one by then. The original bracket should have holes in the intake for it to bolt to.
Yep - Thats them two holes and thats them there bracket...
Is that an Air Gap manifold?
Thank you LongHorn! I thought we had it right, but the bolt we were using didn't fit through the bracket. It fit into the hole which was weird, and it fit through the big hole in the middle just fine. I will look in my garage for the correct bolts :D
