Need CB help
Need CB help
Dan86CJ7
Mass
1986 cj7 258(rebuilt motor/comp cam/weber32/36) T5 300 tcase d30 front(locker/4:10s)
AMC20(locker/4:10s),4"lift,33"s
so i gotta get a CB going as a requirement to go with a local club but the antenna that was there when i got the jeep has a screw in the center, so thought just remove and put in cable? center doent fit. Can any one tell but the pick what my option is..can seem to find a cable that looks right antenna.webp
Is there not an eye on the end of the coax cable??
the CB cable is a female threaded and a center post, i took the screw out and tried to just connect it, and the post seems too big.. do they make a cable without the screw on end on one side? new to CBs only got it to go out with the club
I'd say unless you're attached to that antennae, go get a modern quality replacement.
just dont know what type of hole is going to be left behind if i yank off the plate/antenna mount thats there now..was just trying to use what was there prior to spending cash
you have four options as I see it.
1) pay someone to hook this up.
2)get another antenna.
3) get another cable.
4) cut the end off the cable and put crimp eyes on the center and shield.
Do you have an SWR meter to adjust the antenna?
I would think someone with your club is just dieing to help you with this.:D
Yes it's got a tuner, Its a cobra 29 nightwatcher CB, was wondering if cutting the cable was an option.
So cut one end...one to ground one to center screw. Should work?
Tried asking radio shack about a cable and they just looked at me funny when I mentioned CB radio.
I got my CB from Radio Shack about 10 years ago and the last time I went in one to get a ant. it looked like about all they sell now are Cell Phones :mad:
i said the same to my wife..very bizare! iremember all types of things you could get there and now sadly like you said it was like walking into verizion or something....he even tried to sell us new cell phones.
Yea like there isn't enough Cell Phone stores already. I went over to a truck stop to get what I needed.
I think I'm gonna chop off a cable end and see what it look like..
Dan, your on the right track.peel back the shield a couple inches,twist together and put a ring end on it and terminate to ground. Put ring connector on center wire and connect to the screw on center of ant.May want to put some liquid tape on all the wires after you get done adjusting SWR.Like was suggested get with someone with a SWR meter that knows how to use it.Get your standing wave adjusted and your golden. My '67 had one when I got it and debating about putting it back in.Mostly for the nostalgia look.
mike
Tks Mstar, got plenty of brass crimps/heat shrink/ect, I'm gonna try it, just to try and keep what's there.:chug:
My dad just got me this CB, so all the destructions are there and it walks you through the swrl adjust. So I'll try if not before we go out saturday. if i got issues ill have someone help then.
X (whatever) with regard to setting up with an SWR meter unless you're very lucky you're antenna will need adjusting. One issue I didn't see mentioned yet (mind you I'm going blind in my old age) is in your pic I noticed corrosion in the near viscinity of the nut & bolt. If you're grounding the antenna make certain it's on a clear patch of metal!
im gonna deff. clean up before grounding. gonna try and do it tonight...club going out on sat.
so i cut one end off and all the wires around the center cable is just weaved together and is falling apart, no way to put a terminal on???:mad: maybe i cut too deep
Yes, you cut too deep.
Cut ONLY the outer insulating and do NOT cut the braided shielding wire.
Coaxial cable stripping - YouTube
And
http://www.wikihow.com/Strip-Coax-Cable
exactly what i did....thanks for the pic.:chug: gonna finish after work.
