Need help bad
Need help bad
DIG
Knoxville TN
Ok I have my AMC 304 tore down, the timing chain in it broke and now I am trying to figure out how in the hell to get the gear off the cam......I am at a loss, the book says to line up the the timing marks but if the chain is broke I have no reference to line up the timing marks, I mean the camshaft is a 1/4 of the way out :eek::eek: any help is appreciated..thanks......
The timing marks are only for putting the chain on. Just loosen up the bolt and take the old gear off of the cam. Make note of the order of the oil slinger, bolt, washer and fuel pump concentric when you take the parts off of the cam.
If you havent pulled the lifters and have the cam 1/4 of the way out, you'll never get that cam back in without pulling the intake and pulling the lifters. I'm sure that they have locked themselves in between the lobes by now.
If you haven't pulled the lifters, stop everything, pull the valve covers and intake and remove the rocker arms, pushrods, and lifters before you do some real damage. Make sure you make a way of seperating and keeping the order of the rockers, nuts, pushrods and lifters so you can put them all back in the same place.
I have the motor torn all the way down I keep the push rods and lifters in order but not the rockers or the nuts :( oooppppsss thats why I cant figure out how the gear comes off because when I try and pull it off it wont come off..........:confused: I just pull the cam out
The rockers and nuts aren't as important as the lifters.
If you have removed the bolt holding the gear and the other items to the cam, the gear is just stuck. You can fight with it or just slide the cam all the way out and put it on a bench or something so you can get some leverage. Also might just put a 3 jaw on it and give it a little tweak of the puller...
It will just pop off with a little effort usually.
damn your a lot of help, what about the little gear on the end?? What is that for the oil pump??does that come off with the timing gear? I just ordered a new timing gear from summit ( wanted to do a gear drive but not for 400 bucks) anyway do i need to buy one of those gears also ( the little gear in front of the big gear) ??? I guess you can tell this is my first motor tear down
I've rebuild many engines and would never consider, even with my experience, working without the book on that engine. You'll need the specs and procedures for that particular engine.
If you have the engine down and a chain worn enough to break, perhaps you should go ahead and replace that cam and lifters etc now.
do I need to hae any machine work done??? whats a good size cam with a good lope that i can run?
Like whoa, thanks man! That great stuff there! I am doing all that you suggested except new cam bearings, I have run out of money so I am going to take my chances, hopefully I will be ok!
