Need help Identifying
sbrodacz
Buffalo Grove, IL
-78 CJ7
-Chevy 350
-TH400
Is this some kind of test? Well it's your evaporative canister for gas tank and carb. vapors. Original equipment.
yep thats what it is not really needed with the 350 seeing as you don't have the rest of the emissions equipment
Ok great, so than all 3 hoses should be left open? There is the hose coming from below that I thought connected to one of the hoses, but I am not sure.
If you have a non vented fuel cap the the evap. can. is your tank vent and you will need to leave the correct outlet open or your tank may vacumm lock and starve the carb.
If you can hook it up properly,the vapor can is not so bad to have.
You save gas by saving the fumes that would nomally be released into your garage (or the wind).
I'm just going to assume you don't need an emissions test.
I don't think a 78 needs to pass emissions. I think In IL its early 90s and up.
