Need Help Th400 quadra trac separation
tthstrm179
- CA
- 1978 CJ7 304, Th400, Quadra trac converted to part time and low range
1978 CJ7 AMC 304 V8 with GM Turbo 400 and quadra trac (coverted to part time 2wd with low range).
Developed a leak of ATF at the Transmission side of the adapter. I called a Transmission shop and bought an output shaft seal and a seal kit for the Quadra Trac since it would be out.
How do I remove the adapter plate? It slides back and forth about 1/4", however I cant get it past that. There was a ring around the bearing which I removed however it does not change anything.
Any help is appreciated.
