Need Help Th400 quadra trac separation
tthstrm179
CA
1978 CJ7 304, Th400, Quadra trac converted to part time and low range
Re: Solved one, now question on leaks TH400
Ok, Fixed that issue. Now that the adapter is off, I notice that there is not an output shaft seal, and that the ATF appears to be allowed to run through the bearing and up to the input of the quadra trac. Am I correct that the ATF is contained by the paper gaskets on both sides of the adapter, and the adapter is otherwise full of ATF?
Quadra Trac + ATF = dead Quadra Trac. They do not and should never share fluid. There are two seals on the Transfer Case side that the tranny output shaft seals against. They are not in the adapter or the Transmission .
Thanks. The Transfer Case has been converted to part time; what is the correct fluid for it?
