Need help with V-Belts
cuban11182
CORPUS CHRISTI
84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
I've been searching now for a bit to see if I can find my belts online so I can replace them. The problem is I have no idea what the numbers on the belts mean, so I can't cross reference them. My AMC 258 i6 / 4.2l came with Power steering and A/C. Looking at them it appears I have 3 belts. One goes from the PS to waterpump to the crank. One goes from the crank to the AC compressor to the water pump. And a small one from the AC compressor to the alternator. There is no smog pump. The numbers I have are:
15485DC 11AV1230
13250DC 10AV0635
17465DC 13AV1180
Any help is greatly appreciated.
I'd just take the old belts down to the local auto parts store and match them up.
But to answer your ? with Gates belts the numbers would mean
48.5 inches
25 inches
46.5 inches
Not knowing who made the belts though, makes that just a guess.
Old dog is on it again. Goodyear gator back numbers 48.5"-25.25"-46.5" 3/8 wide they should be
I ended up using the second set of number, without the V. I found Duralast belts at my local autzone and put them on. That A/C to water pump to cranks is a PITA.
Thanks for the help though!
For anyone looking at this in the future the belts for my Jeep were, Duralast 15485, 15250, 17165.
