Need help !!!
Need help !!!
Reddrig
Ca
1972 Jeep CJ5 304 T15 Dana 20 Holly Carb
Dana 44 rear
Dana 30 front 4.27 stock gears
Front and rear power disc brakes
35" Mickey Thompson tires with Mickey Thompson 17" wheels
Rhino lined tub with custom tool box
Rugged Ridge ORV 4" lift, 1.5 BL
I see you are doing the same thing I'm about to do. I may be picking your brain if you don't mind!
This is insane. I'm even using a pickle fork to try and pop the lower joint to remove the knuckle. No luck, I have a headache and still can't get this thing to pop. This has been the worse project yet on the jeep. I've hit it with everything I have.
Just poped my first cherry. After 2 solid hours she gave. Blood sweat and grease everywhere.
