Need K&N for my 4 barrel?
Shazam
North Carolina
1979 CJ-5 Renegade with '74 304 V8 & Edelbrock manifold & carb, Heddman headers & sidepipes, T-150 3 speed, Dana 20, Dana 30, AMC 20
OK guys...fighting a gas smell which turns off the Mrs. Tracked down and repaired a leaking return hose from the fuel filter.
Now...a friend of mine says my carb (1405 Edelbrock - 600 cfm) doesn't have a vacuum secondary...meaning all 4 barrels are used all the time. That's too much fuel he says and he could be right. He says a K&N will allow more air which will burn the extra fuel - stopping the lingering fuel smell. Thoughts before I spend 50.00 on one? many thanks. :chug:
I don't think it would make any differrence in the gas smell.
I also believe your friend is wrong about all 4 barrels working all the time, the back 2 barrels shouldn't open till the linkage is oppened so far.
Take the aircleaner off and watch them open while you work the linkage.
yep....4bbls are designed to run with the primaries only until the throttle linkage engages the secondaries. At that point, you are well into the gas pedal.
cant imagine how an engine would idle with the primaries AND secondaries open all the time...no matter how much air you put to it. :wtf:
Great info - thank you all. I cannot tell you how much I appreciate the help and guidance here. Hopefully before long I can begin answering as much as I ask :)
BTW, K&N`s are awful as filters. The amount of small micron particles (those are the ones that do the most damage) that the filter let`s pass through is unacceptable.
Do you have proof of this? A properly oiled K&N uses a static charge to draw the particles to the oil, and therein lies it's effectiveness. Oiled improperly or not enough and you might as well not run a filter at all.
Just curious. I've ran K&N's for years and haven't heard of this being an issue when used correctly. I would think the designers would test filters for particle saturation and bypass
