Need pictures of serpentine belt setup
coldair
Full Time Jeeper
wyoming
1986 cj7 in the works,
1996 F350 crew cab with a 5.9 cummins
I need pictures of the idler pulley bracket set up. Thanks in advance
That is what I needed same setup as my 86 CA model.
Mine is an 81 CA model, so I believe one of the early ones to get a serpentine belt. No A/C, and the smog pump had been removed, so I wrestled with the idea of using a newer pulley system(mid 90's). I ended up using my stock setup, with the exception of where the smog pump is, I pulled a pulley off of a late 90's Grand Cherokee.
Sorry about the pic being sideways, I'll try and do better next time!
I'll go out and take a couple of better pics so you can see how it came together.
You can also try this out if you haven't seen it- Pulley pics
I am going to install the Howell FI kit, and would like to remove the air pump, so I really like the pulley that you have added. Is it purely a bolt on fix from a late 90's GC, or are there modifications needed for this to work?
Thanks, I appreciate the help.
Joe Zeppe
OK, so I looked at your pictures again and realized that you just bolted an idler pulley through the threaded hole in the bracket. :chug: Such an easy, and simple solution.
So I went to the local wrecking yard, and found a pulley off a Ford motor (don't know, nor did I care, but I should have looked) and found it have a nice bearing in it, and it was the only one that would work for what I needed. I came home and I turned down a shaft that would fit the ID of the bearing, and an OD that would support the side of the bearing. I will have to figure out how far to cut it to, so it lines up with the belts.
Thanks, I will have to post pictures, but they will not be as clean as yours. What size/length belt did you use? PN?
Thank You,
Joe Zeppe
I think pretty much any grooved pulley will work, I just happened to walk by a GC and noticed it, so that Ford one should work just fine. I also had to machine a collar for it, but it wasn't a very big deal.
I believe it is a 7/16" bolt that is 2.5" long. I also added a 1/4" piece of plate on the face of the bracket for some strength, not sure if it helps, but it does give me a little piece of mind.:dunno:
I'm using washers there now to test out the position of the pulley, so far it's working, but the engine has only been in a couple of days.
Do you have a PN or length for the belt?
Autozone part#870K6
It's kind of interesting, I went through maybe 10 belts before I found this one. Prices ranged from $14 up to $36, with the $36 one being shorter and the $14 one being longer. :confused:
And I just noticed you were asking about the belt # earlier, not bolt. :o
Did you have make the bracket that the pulley is mounted to?
yeah, I had to make the bracket, and the spacer that the idler bearing sits on, and the spacer that clamps within the area that the smog/air pump was.
I got a little impatient and mounted it while the paint was still wet.
I cut it out of a 5/16" x 5" steel bar I had in the garage, then bent it up.
I started with a cardboard template.
Joe Zeppe
:us:
Probably what I should have done, I guess time will tell.
