Negative wire of the Coil Connector-what is this?
ScottB
Rockwall Tx
1984 CJ-8, I6 258, T5 tranny, Dana 30 front end, AMC 20 rear, Dana 300 transfer case
I found this in the negative wire coming out of the coil connector. I'm not sure what it is. I looked at the service manual diagram and nothing is shown in that wiring diagram. I'm about to do the Team Rush mod and wondering if I can just cut this thing out. I'm also wondering if this might be the reason my factory tach doesn't work.
Scott
As a side note, do you need to do anything to the factory tach if you do the entire Team Rush mod?
I think that is the wire for the tach.
I however, am not positive of this...
http://www.jeep-cj.com/forums/f2/teamrush-ignition-upgrade-11416/
There is a write up on BusaDave just doing the mod, but i do not notice on his diagram where that wire went to.
I think the MSD box would send the tach info to the gauge in this above instance...
All of this is just assumption though, so I'd wait for another reply if I were you :cool:
~ JR
This is one that is on mine.
I think that is a ballast resistor if i am not mistaken... And i very well might be...:cool:
I think the OP has got the Tach wire(i assume), you're showing again what i assume to be the ballast resistor. Mine does not have one, so I can not be certain of that...
Paging Doctor Busa :cool:
~ JR
It's inline in the green wire that runs from the negative on the coil to the ignition module. I don't see anything in the service manual on that wire other than the plug to the ignition module.
Scott
~ JR
That actually may be the condensor. looks like what was inside my original distributor... But back to the OP's question, I still really think it is the tach wire.
Not sure, but really think so. Busa is here though, he'll probably shed some light on the situation :D
:p
Ballast is on the hot wire.
Thought I was wrong about that... Was I right it was condenser maybe? :cool:
:notworthy:
I have an '81 CJ5 and the green wire goes to the idle speed switch. The PO added a separate tach and ran a wire from this one to the tach. The schematics for an '84 shows the green wire going to the Ignition Module. It probably serves as more than just a tach function.
Tommy
Thanks for the replies. I always say "when in doubt, cut it out". So when I get home, its gone.
this is electronics and not household wiring
in electronics, black is ground, and green is not a identified ground color, so just because it is green does not mean it is a ground, I think you need to trace the wire back to it's source, after all it has been a generation since the last CJ was built, it could be almost anything:chug:
