New 85' CJ; won't idle
Ok Breakdown:
1985 CJ7 AMC AMC 258 i6 / 4.2l I6
5 spd
Weber Dbl Brl 32/36 carb
Looks to be fairly stock motor, the carb looks modified; no choke plates, rectangular instead of circular air filter.
The guy I got it from said that his buddy mentioned that it needed a valve job. It was blowing white smoke untill he put some additive in the oil to prevent that, is what he said.
Seemed to drive here fine and was holding a rough idle once the engine reached operating temperature.
I took the carb off & cleaned it, replaced the master brake cylinder, new air filter, inline fuel filter. I forgot to buy new spark plugs, when I pulled them they were and burnt/rusty red but not oil fouled. I cleaned them, gapped them, and put them back for now. Wires appear new, routed correctly, rotor and cap also in good shape. Going to replace spark plugs and test cylinder compression tomorrow.
I drove it around the yard a bit this morning and it seemed to idle roughly, then i let it sit for a bit. came back about 4 hours later and let it warm up again and it wont hold idle now.
Thought it might be low on gas, filled it up & replaced inline fuel filter.
I could only find an inline fuel filter, nothing else. Is there a filter in the tank? I know that the jeep was parked for the last 8 months without fuel, and i know
got poured into the tank.
So far I am debating blowing my fuel lines out, draining my tank, looking for an air leak.
Any thoughts?
After reading a couple other posts on here it seems that vacuum leaks around the carb can be problem causing, as well too much fuel pressure (>3psi) to the weber is a problem.
I would let to set the weber back to default settings, but i'm not sure ho much to mess with things, I know this jeep was running good at one point but that could of been years ago. The previous owner never touched, fixed, or maintained anything.
5 spd
got poured into the tank.So far I am debating blowing my fuel lines out, draining my tank, looking for an air leak.
Any thoughts?
