New Gas Tank, Trying to start up the cj
khass0410
Pilot Point, TX.
75 Jeep CJ5, 4.2L Straight 6, Dana 44 & 30? T30 TC? 3 Speed,
I put maybe 2 gallons of gas in the new tank poured a tiny bit in the carb. it starts for just a second then stops do I need more gas?
Dumb question....I figured it out
Thx
Id put a little bit more into it, but more then likely you need to prime the linesLAst time I started a jeep that had the tank replaced it took awhile. put some gas down the carb.. start it and keep it going by manually giving it fuel. I used starter fluid to get it primed. We also had to replace the fuel pump. My method might not be the most favorable..
