Members CJs New member! My 1981 Renegade.
OldSeaDog
Featured
Arkansas
1981 CJ7, 258, TF999, D300, D30, AMC20
Looks like it’s a good starting point. Hopefully solid underneath. That front bumper is no joke!
What have you got planned?
Right on! Doesn’t look too bad or rotted.
As you go tip to tail, you’ll find odds and ends to address. Like…
The winch cables look suspicious, beneath the front cross member.
Be advised on those healthy wheel spacers it looks like it has. Check the attaching nuts often.
Front driveshaft?
Have fun with it. Wish I could be wrenching now too, but too cold in my unheated garage.
Front driveshaft?
According to the PO there are no wheel spacers on it. I haven't taken the wheels off yet, probably should do that. Winch cables definitely need to be rerouted. Fuel tank was new along with aluminum radiator. I have replaced fuel sending, all questionable fuel lines, water pump, thermostat and housing, rebuilt the weber 38/38 and reduced idle jet size to 50s. Next up is differential service. It runs great and I can drive it with one finger.
Front driveshaft?
I stand corrected. Those are some healthy wheel spacers. Lol Front drive shaft was being rebuilt when that picture was taken. It has been installed since then.
Like Said, that is a Massive Front N
Bumber and a Oversized Winch.
It is going to seriously effect your Approach Angle when Off Roading.
My Off Roading Rig is a Samurai I call the Timber Cruiser. I Don't have a Permanent Mounted Winch. I have a 6,000 lb winch on a 2 inch receiver bracket and a 2" receiver front and rear. It is securely stowed in the rear area.
Now I can get my <-BAD WORD-> out of a Bad Situation from either end.
And why only a 6,000 lb winch?
First, it's lighter and doesn't take Two Men and a Boy to set it up.
Second.......
I ONLY Have to Get ME OUT!
Not your Family Sized Rubicon!!
Rule of Winch size. Double the Weight of the Object being towed. So I'm right there at 6,000 lbs
The Timber Cruiser weighs it at 2,800 lbs with trail gear and my
Beer Goiter in it........
Just my Nickel.95
Cool,
Better pix of the Approach Angle.
Happy Trails
$100.00
  50.0%
