New owner - couple of questions
JeepCJ5
El Paso, TX
'81 CJ5 - 258, D300, AMC20, D30
Pull the insulation off the hood, go to a muffler shop.
These beasts make noise. It's part of the CJ Experience.
When they fab the exhaust have it angled at 45* at the tailpipe, that should keep the fumes from swirling back into the cabin.
Luckily, my 76 CJ is a non-catalyst vehicle. And I don't have to deal with smog-nazi's where I live.
Oh: :ww: To The Forum!!!!
Thanks - I was leaning toward taking it to a muffler shop - I'll just go that route.
I want to sandblast the hood anyways, so I'll rip off the insulation and see what difference that makes.
Ask for some recommendations from the guys/gals on this forum for a exhaust shop. Someone in your area probably has a good experience (or a bad one). I really hate having to re-do things....
Post some pics of the underside. Especially the springs. Looks like you've got a lot of lift. Probably 4". What tire is on the CJ? And how does it drive? Any issues with 'darting' or 'wandering'?
Wow!, I didn't even know that the CJ even came with hood insulation, unless it was an aftermarket add on. I would have to agree with removing it permanently since under the Texas sun you would want to keep the underhood temps down anyway.
They never came with insulation from the factory that I know of. Maybe dealer or PO installed.
Is your fuel smell raw or exhaust?
:ww: :dbanana:
X2 on what Posi asks.
Get rid of the 'blanket', before it falls into the fan belt.:eek:
What carb do you have on it?
Don't know it this will hepl you much.
Table of Contents
Hey guys, thanks for all the tips - I'll ditch the blanket. This Jeep lived up in Cloudcroft,NM for a long time, where they actually get snow, so that's prob why it is there. The smell is exhausty. I dropped it off at a muffler shop today. Hopefully that fixes it. If not, I'll start checking the carburetor.
It has a 4.5" Rubicon Express lift on it with 35" tires. It drives nice. Haven't noticed any darting.
Is the smell while driving, or at idle or both?:confused:
Where does the exhaust exit?
Smell is all the time when the engine is running. The exhaust exits under the bumper below the license plate. It was cut straight off. I am having them turn the end down.
CK your fuel mix, and make sure you are run'n the correct plugs.
What's the ign timing set at?
Thanks LG - the new exhaust helps, but I'll also follow your suggestions. I've only had it a couple of days, and haven't had a chance to do much. I have seen some info on the nutter mod, and the muffler guy talked about the charcoal canister causing bad smells also.
I haven't checked the timing yet.
The charcoal canister can give off a raw fuel smell if the filter gets clogged as it blocks off the fuel tank vent system. The Jeep CJ fuel tank vent system is somewhat complicated, you might want to look it up. The Nutter Bypass will affect the computer operation of your Jeep if you even have one. I am not sure all of the CJs had computers in '81.
The only Cj I know of that came from the factory with hood insulation was the '82-'83 Limited thats it.
Torx is right. The computer controlled BBD carb didn't start till '82. You can stop concerning yourself with the Nutter bypass cause your carb pic confirmed there's no plug in the back of it.
