No park/marker lights
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
A while back I installed (my first time) a full new wiring harness and fuse box in my CJ7 .
I was able to make all lights work (backup, turn, brake, headlights, hazard) except I still can't figure out why the park/marker lights don't work.
I've tested the headlight switch with the ohmmeter and it connects to the power source when I pull out the headlight knob. I've checked all the wiring and took off the ground wires cleaned the paint off real good then put them back on, and nothing...
I know that the bulbs for turn are the same for park but heard the circuit is different...
I've also checked the fuses.. All are good...
If anyone has a suggestion on how to troubleshoot this issue, I would be very thankful...
(please help!)
(please help!)
and at that time only the marker/running lights worked and then NO turn lights...
