no rear brakes (1978 cj7)
ksouthw80
- georgia
- 1978 CJ7.304, t150,D20 w/teralow- twin stick, dana 30/AMC20. 35 sst's on procomp wheels.
I just installed a new mastercylinder(bench bled), a new proportioning valve, and all new premade brake lines and I have no rear brakes. There is very little fluid to the rear, almost residual. The pedal stiffens up somewhat. Is it possible it needs to be pressure bled? Maybe a bad Pvalve? I have cracked all the lines in an attempt to release any hyd lock. The pvalve does push fluid once built up, then no fluid seems to leave the master cyl. ? ? ?
