Do you mean starter solenoid or starter?
If you mean starter solenoid then no it wouldn't rule out the red ignition wire. You have battery voltage at the ignition side but you have a voltage drop of 3+v from there to the coil. Chase the red wire to the splice and see what's going on there.
Do you have a stock coil and distributor?
Sorry Posi, I meant starter solenoid. I do have a stock distributor with the Team Rush upgraded taller ford cap and a high energy e-core coil.
Here's an update to my problem after quite a bit of more troubleshooting this evening:
Engine won't start, no spark from coil. The Howell furnished ECM is working normally as indicated by the check engine light coming on in the run position and staying on while cranking. The electric fuel pump kicks on for a few seconds when the key is in the run position but then does not come on while cranking (as it should) probably because it isn't receiving a tach signal.
* I do have 12V to the ignition side of the starter solenoid while cranking (I think I had my digital volt meter on the wrong range when I previously reported lower voltage, sorry for the confusion).
* I have about 1V less than this (11V) at the positive side of the coil while cranking.
* I have 12V to the red wire going to the Duralast ICM and 12V while cranking to the blue wire that goes to the module (white on the module side).
* I installed my brand new spare Duralast ignition module (no change).
* I installed my brand new spare e-core coil (no change). Both coils tested about the same with my ohm meter with about 2 ohms on the primary and 8000 ohms on the secondary
* A few weeks before the failure I installed a new coil pickup in the distributor. Is it possible this part may have failed or would I still get spark out of the coil even if it has failed?
The only other thing I can think of is the green wire from the ignition module to the negative side of the coil. I tested the resistance between the coil and the icm and there was not an open and was about 1 or 2 ohms. Does anybody know what voltage I should be getting at negative side of the coil while cranking?
Please guys, I'm at a loss and have been spending several hours each evening trying to figure this out. My last resort is to tow her to a shop and let some guy I've never met before have a crack at her! I'm a serious DIY guy (great at some things, not so great at others) and can't bring myself to do this!
