NON-Running Engine Issues?
45frank
- Mountains Western NC
- Past 77 CJ-5, 84 CJ-7, 78 CJ-7, WIP 80 CJ-7
OK finally bought a 1980 CJ7 with a 258ci 6 cylinder with 105,000.0 miles and a fiberglass tub. This is my 4th CJ and with the front end so tight and lack of rust on the frame it's believable. It sat for a long while and was a primary hunting vehicle in southern Ga. If this is posted the wrong area please move it, I have a few issues and will be spreading them to the proper threads(forums).
First where you put the oil in the valve cover it is vented and oil seems to leak from there. It's about a 6" extension above the cover. Is this supposed to be vented or a cap? Also I was told yesterday the dipstick isn't the original and is short so it may be overfilled. I will be changing the oil and filter in the next two days to see.
1) I also need the grommet that holds in the PCV valve the one there is swollen and loose and the PCV valve bottoms out.
2) Many of the vacuum lines are plugged because some PO put on an after market air filter that's no bigger than a softball.
Where can I get an original and will a cover from any 258ci engine with a one barrel fit so I am not calling junk yards asking for a specific year?
Other than this it runs very well.
On to the Auto Transmission , my first Auto. Is it hard to adjust the linkage? It sit in the 2 spot when Driving and is hard to get in Park, runs out of room.
Thanks to all that have done more than me!
