Np435 end play
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
Just a little confused. Have a rebuilt np435 that I recently installed the Novak adaptor to adapt to the Dana 20 . Got the adaptor on (dry fitted) and torqued. Got the front input bearing retainer housing on with the input shaft (dry fitted) and torqued. I can't for the life of me figure out how to properly set end play. I know how to do it with the dial indicator and what not but as far as specs and how to do it, I'm confused. Spec is .006-.012. Do I measure this off the front input shaft? Rear shaft? Any help would be great. Thanks!
Everything sounds good to me. Everything should be turning easily without binding.
