Ongoing Dana 300 Build
simple man
Concord, NC
'84 CJ7
Well, I have gotten the input shaft and front and rear output shafts and the bearing covers together*and attached to the case. *
In trying to check and see how everything is fitting together I attempted to see how the shift rods moved. *The rear output rod moves OK but is a little stiff. *However the front output rod is almost impossible to move in and out. *If I disconnect the front shift fork the rod will move in the case but it is still VERY hard *With*the front shift fork is disconnected it does not seem to move smoothly along the rod. *Is this just an issue of there not being enough lube on the rod, even though the rods were coated with engine assembly lube when put together? *Or, could it be a problem with the line up of the interlock plugs?
Any suggestions?
Rick**
Don't have much experience with the 300, but on my 20 it was a little tough to move them too after the fresh rebuild... They are fine now in the jeep lubed and with the shifters...
Have you squirted any oil on the sliding contact areas? :confused:
I rebuilt mine a while ago and havent got it on the road yet, it is also very stiff to shift, i think yours need oil splashed around in it like mine to get it to shift well
TCase Dana 20
$70.00
  35.0%
