Build Thread Operation Sky Blue Water Trip Build
Yes nice work. Looks great!
That is absolutely gorgeous....... I'll,be lucky to have mine turn half that nice!!
If I can you can. Take your time. Read. Read. Read. Be patient and you'll be fine.
Great job figuring out the problem. Really looking forward to seeing this in person. Want to see the computer data and tuning. We are so happy for you! 😀
Great job figuring out the problem. Really looking forward to seeing this in person. Want to see the computer data and tuning. We are so happy for you! [emoji3]
Thank you so much I appreciate it.
:banana::chug:
Good work! I don't think I would have had the patience to calmly figure things out without a few wrenches being launched skyward! (That's why I married an electrical engineer!:D)
Just like a new Jeep now! That's what a hot spark, and FI will do for you. Well done!
Great team work, along with excellent detail in corrective actions. :notworthy:
Wow. Great job figuring that out! Attention to details
Awesome 007 - can't wait to check this out in person in a few months!
Even though pretty much everything on ours has been rebuilt, we are starting to consider one........................:rolleyes:
Our unfortunate motto: Money..........Parts...........Repeat
Tried connecting to video but no luck. Removed . but still no luck :(
Hope that last one works. When I first posted it it had not yet processed.
The video isn't very clear as to what you're looking at but when the timing light hits through the hole in the distributor cap you can see where the rotor terminal aligns with the number one post.
I think it's pretty clear, even I understand it 😁
So here's the wrap-up of the Sniper EFI... It's one heck of an upgrade. It's so, so nice. Holley support has been great and between them and their cousins at MSD they helped me through the couple sticky spots I got myself into.
Lessons learned:
  • Read read read read read read read read read read read read read read read read read read read read read read read read read read read read read. When you're done then you can re-read read read read read read read read read read read read read read read. At this point you will have retained about 70% of what you'll need to know. :confused: :D
  • If you install a Sniper, pay attention to the docs (obviously) but it DOES say to install it WITHOUT timing control to get it dialed in, then do the wiring and distributor work to let it control timing. I didn't do this, but it didn't bite me. I can see however how it could have. It's not much work to do it their way - like about an hour to change it over from no timing control to timing control.
  • I would never suggest doing one of these without adding an MSD6 box and the MSD ProBillet distributor. It definitely adds some expense, but you have it all torn out anyway - why do it twice?
  • If you do this with timing control, you probably won't get away with your stock Motorcraft distributor, you need more precise timing between your reluctor and your rotor / plug terminal.
  • You will need an MSD tach adapter to make your OEM tach work. Our OEM tachs are current based, not pulse based.
  • If there's anything not fresh in your ignition, now's the time to replace it (coil, wires, plugs).
  • If you have the stock air pump that pumps fresh air into your exhaust, it WILL throw the O2 sensor off and thus the computer off and your target AFR (air fuel ratio) and advance curve will be off. Remove the belt, or the pump or the main hose - up to you. Not sure how this will affect smog folks, but you may get by on the increased efficiency of the EFI, if not, hook it back up for your testing. If you still fail, manually set your AFR via the handheld.
  • This unit is on par with a 750CFM carb - fyi only.
If you decide to go this route, don't hesitate to reach out to me, I'll help wherever I can. I don't know it all - that's for sure, but I've done one now and I've learned a lot. I also won't tell you something I don't know either, I'll defer to the manufacturer - just like I had to do. I'll be doing this all over again on the Cherokee, I'm actually looking forward to it.
The Jeep goes to the shop tomorrow supposedly to have the one-piece axles installed and a rear brake line replaced.
$150.00
  75.0%
