Orange sparks from exhaust manifold????
Junky CJ
Alright, so I'm Jeep newbie looking for some help. I just bought this CJ5 with the AMC 258 i6 / 4.2l and it had issues from the very beginning where it would stall out on the road. Symptoms were similar to vapor lock in that it would start to stall at no particular time, losing power and jerking forward, feeling like the fuel was cutting out or was maybe too rich, sometimes it would backfire.
After adjusting the carburetor, putting in a new fuel filter, hunting for vacuum leaks, and removing the manifolds to look closer for any holes or anything of note, we decided we would replace the timing chain the next day. Now at the time when we ran it no sparks appeared. Still would backfire mostly at high RPM.
We replaced the timing chain today, the old one was very loose and after we drove it briefly, it seems to run smoother, but backfiring still occurs and now orange sparks are appearing from somewhere under the manifolds when we rev it.
It is important to note there are small exhaust leaks on the manifold the previous owner seems to have welded over, but not completely sealed. There is also no catalytic converter, but the sparks are appearing in the engine bay beneath the manifolds, not in the exhaust pipe. We've tried adjusting the carburetor but it doesn't seem to help. We already tried putting oil in it and seeing if the oil is flowing under the oil cap, so it appears to be fuel getting into the exhaust manifold. Has anyone ever dealt with this before? Should I be looking at the fuel and air system or did we do the timing chain incorrectly? Could the distributor be messing up the engine timing still and causing this issue?
Basically, now that you've heard the story of my 1,800 dollar basket case CJ, can you tell me what to look for and check on?
