PCV Valve help from experts
Reddrig
Ca
1972 Jeep CJ5 304 T15 Dana 20 Holly Carb
Dana 44 rear
Dana 30 front 4.27 stock gears
Front and rear power disc brakes
35" Mickey Thompson tires with Mickey Thompson 17" wheels
Rhino lined tub with custom tool box
Rugged Ridge ORV 4" lift, 1.5 BL
Well, I don't see a pcv in the pic, but I do see an egr which is also a good thing to have even in a no smog required vehicle. That egr should also have a thermal vacumn switch so it will not be used on a cold engine. If you have diagrams for the pcv install what is the issue?
Well I don't see a pic at all but You should get a new PVC valve mount it in the valve cover and run a hose from it to a vac port at the base of your carb.
