pitman arm
oldguy
OK guys, I know this topic has probably been beat to death BUT I'd really like some help. I have a 78 CJ5 with the turning radius of a mack truck. I need to know the dimensions of a "stock" pitman arm from a 78 "or so" CJ. The PPPPPPPO put some kind of drop (about 4") arm on it but it looks short hole to hole. With the new setup I have that amount of drop isn't necessary. About an inch would work or two would be great but I need it longer "hole to hole" than it is now. SO long story short -- whats the dimensions of a stock CJ or Waggy arm, will a Wrangler work, how about a Scout II????? Any of you out there with the same problem or maybe just wanted to tighten up the radius -- what did you do??
