Plastic Valve Cover Replacement.
Petescj
Member
Lifetime Supporter
Featured
PA
1982 CJ-7 258 / T-18 / Dana 300 31 in All Terrains.
1978 CJ-7 304 / TH 400 / Quadratrac 32 in Mud Terrains
Tried a search in the drivetrain sub forum an didnt come up with much. I believe my Scrambler has the plastic one with the rocker bridge. Alot of replacements out there say the wont work with that set up.
Please tell me Im not stuck with a plastic replacement. :(
Pete, You won't be with your new 4.0 head! That in itself is another major plus with the 4.0 head that I don't see anyone mention, the system is the real deal compaired to that lame AMC 258 i6 / 4.2l leaker.
Pete, You won't be with your new 4.0 head! That in itself is another major plus with the 4.0 head that I don't see anyone mention, the system is the real deal compaired to that lame 4.2 leaker.
Gotcha on that. The 4.0 head isnt for this AMC 258 i6 / 4.2l though. It can get a little confusing when you have 3 of them. :D
you can do away with the rocker bridges, i did, and put an aluminum valve cover on it.
Ok but what the :censored: were they there for in the first place? :confused:
Gotcha on that. The 4.0 head isnt for this 258 though. It can get a little confusing when you have 3 of them. :D
If the 4.0 head is good for 1 then it's good for all :D.
they were there to help hold the plastic valve cover down, think about the later model chevy centerbolt valve covers, similar. you know now that i think about it i might have left em in there, but knocked the studs out of em, i can't remember now pete, but i know they was there and not any more, :dung: that's been over two years ago since i built the motor and put the valve cover on.
You should be able to buy an aluminum cover for the AMC 258 i6 / 4.2l only problem is they used 3 differant heads on the 258 and you may have to drill and tap 2 holes on the driver side of the head. And take out the kinesurtes on the pass. side to get it to work this is what I had to do but with the aluminum cover I haven't had to valve cover leak since.:chug:
