Please Help me! I need to remove my 258 engine fan spacer!
76cj7chick
Old Time Jeeper
WA
1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hi all!
This may sound dumb but, I am having difficulty with removing the fan spacer off of my 76 CJ7 AMC 258 i6 / 4.2l engine.... The po left the spacer on but no fan.
I have a 3 core aftermarket radiator on the CJ7 which leaves little room for the engine fan.
I've been told that I can remove the fan spacer to get extra room to install an electric fan...
I took off the four retaining bolts holding the spacer but it still won't come off... Do I have to remove the pulley to take the spacer off?
I event tried to hammer flat headed screw driver between the pulley and the spacer with no luck..
Do I have to get a hold of the middle rod thingy and pull it off or twist it or??
Please help me with my current headache... Thanks bunches!
:notworthy:
I've included pics of the spacer on the fan...
take the belts off and the whole pulley should come off.:cool:
"should" it might have gotten pressed on to the pump shaft
Sent from my XT907 using Tapatalk 2
Put a little penetrating oil on it and with all the bolt out take a hammer and a punch and spin the spacer free. Get it a little loose and give it another shot of penetrating oil. the aluminum gets corroded and it gets stuck.
What if I don't want the whole pulley to come off, just the spacer? Would I still have to remove the entire pulley? :eek:
Eeek.. If it is pressed to the shaft what kind of puller would I need to remove the spacer? And can I just put the pulley back on skip the spacer and then use shorter bolts... Why? So I can install an electric fan. :o
Thanks for your help!:)
I've sprayed almost a half can of WD40 on the spacer over the last 5 days and tapped on the spacer with a hammer and tried to get a thin bladed flat headed screw driver between the pulley and spacer with no success...:confused:
However when I first tried to remove the spacer it wouldn't budge at all... But after working it over the weekend and week it now will slowly spin but shows no signs of releasing... Hope its not pressed onto the pulley. :(
I would just try and remove the pully like stated before it will give you more leverage all it takes is pulling one belt off of just that pully.
It shouldn't be pressed
Yup, try that. It may be peened onto the pulley. Let us know how it turns out 'cuz I'll be doing the same mod soon.
I'm with removing the belt, it might be making the pulley and spacer bind up. You really want the belt off when you put the bolts back in the pulley anyway.
Previous owner may have epoxied or glued it on. Try something wider than a screw driver, like a paint scraper. Also, WD 40 isn't the best penetrating oil. Maybe something stronger. Maybe use a hacksaw blade. I just pulled my spacer this week so my new radiator would clear the fan. Mine came off stuck to the fan.
Thanks everyone for your suggestions... I think I will have to take the belts off.. :(
Just hate re-torquing everything.. Why? Because I don't trust my self when it comes to fixing things... And yet, I still do it... :p
I will let you all know how it goes.:o
By the way... Just for clarification... If I loosen up the belts should the pulley come straight off?
What about the middle rod? Do I re-use it or get a shorter one for the pulley? :confused:
:notworthy:
GOT THE SPACER OFF! :banana::banana::banana::banana::banana:
So, my dad came over this weekend and "monkeyed' it off. In other words he tapped on the pulley with a screwdriver and hammer... Nothing broke... :o
Here are some pics. Thanks Everyone for your help!
The last picture is of me after I colored part of my hair HOT PINK... I guess to match my CJ7 .. :p
Glad to to hear you got it off :chug::chug:
My dad always said if at first you don't succeed....Get a bigger hammer.
That never works for me, I just break :dung:.
Glad you got it handled, enjoy the time wrenching with your dad.
