Did you install all of this? or a shop?
with all that new you could have a multitude of problems on the tuning end.
ok, what is the manifold vacumn? and what is the recomended vacumn for the engine, is that a stock carb or a upgrade? Who set the float on the carb? whi set the preasure from the fuel pump. or does the carb have a preasure range it need to receive and or be restricted to? Who set the distributer? are they sure the thing is in perfect alignment with the crank? could it be off a gear or 2? have you set the dewell properly? All wires in proper place? Last thing I would worry abouut is a new Cat till all the other things are checked.
One more thing, the linkage to the accelerator pump, see if that is working good as a first step.
