ported vs manifold
ported vs manifold
IrishCJ6
Ireland
1975 CJ6
AMC360, D150, D20,
I know it's been talked about before but I'm toying with the idea of switching my system from ported to manifold vacuum. It's an AMC 360, MC2100 all the smog kit has been removed and I've added a hei dizzy.
Question is what initial timing is everyone using, and what total amount of timing.
As a general rule with manifold vac. you want the timing to be all in with 32-36* @ 2500-3000rpm's with no Vac hooked up. (Depends on your engine)
With that in mind I have about 12* with no vac. at idle. With the manifold vac. hooked up it's around 22*.
Well had a play today, found that the vac advance gives me 25*, so to get a max of 32-36 meant pulling the initial back to 0. Seems to run good at that. Have to recheck the total again and could maybe advance a couple degrees more on initial. 25* seems a lot.
0* initial - vac disconnected and plugged.
32* total at 2800
25* at idle (750 RPM) with vac connected.
What you guys think
the hardest part to get your head around is the idea of an increase in Vacuum, or in other words, more of nothing.:D
Manifold vacuum drops on acceleration and ported increases. less of nothing with manifold and more of nothing with ported.:laugh:
32* total at 2800
What you guys think
At the end of the day it has to be what your motor likes best :chug: sounds pretty good so far. You should have an allen screw inside the vacum canister on your dizzy if you ant to add some initial mechanical timing in it
sounds like your vac. advance might be pulling to much timing, I set mine to only pull 10* but that's what mine liked.
I have a NLVR (Non Linear Vacuum Regulator) which attaches to ported and manifold vacuum then goes to the distributor. As I understand it, this was an emissions control device. I was thinking I'd just disconnect it and go from manifold direct to distributor and cap everything else.
My total advance is incorrect, I didn't do it properly so ignore that figure,
Question is, is 25* vac advance normal, can this be reduced if so how? I know that once the throttle is applied the vac advance will reduce to zero and the mechanical will set in but if for argument sake I set the initial to 12* and find that I achieve 32* at full RPM (say 2500-3000 rpm), if I reconnect up the vac to the canister I will be at 37* at idle (12*+25*). Is that ok or too much?
I'm running on of these dizzys
AMC Jeep CJ5 CJ7 304 360 401 V 8 Hei Distributor 6512 R | eBay
Yes 36 at idle would be to much.
Your vac. can should not be pulling 25, there should be a way to adjust it to only pull about 10. Some you can adjust with an allen wrench and some you can adjust the rod.
