Power/Oil Pressure Drop Off!
- Featured
- 1
- Media
- 9
- Pittsboro, NC
- 1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
Hey Guys,
(Note: It’s worth letting you guys know that I recently bought this CJ5 , and I’m still trying to get the temperature and fuel gauges fixed. One’s not accurate, and the other doesn’t work at all.)
So we had are first truly warm day today, and I took my CJ5 out. The day before I changed out the ignition coil. It seemed to fix my rough idle, and my acceleration issue. I drove it for several miles without incident.
This morning, I got to my regular coffee shop without any problems. After being there for about an hour, I started driving back home. About half way down the road, I started loosing power. I would press on the gas nothing would happen, then after a couple seconds it would start to rev-up again. I was able to get to 55mph, and make it home.
I initially thought I was just running out of fuel, so I drove down to the gas station. I filled it up, and started heading back. It was then I noticed my oil pressure gauge was at 20 psi. I immediately pulled over to check under the hood. The oil level was good, and it didn’t feel like it was overheating.
I was able to putter back home, trying to go as slow as possible 35-40mph. The gas station was less than a mile from my house. The oil psi stayed around 25-30 psi throughout the entire drive. Before today, it was almost always around 45-50 psi. The lack of power was even worse then before, and it started idling rough.
I got home, checked the ignition coil, spark plugs, and wires. Everything seems securely fastened. After letting the engine cool, I checked the radiator, and the coolant level was good. I looked underneath the engine, and I couldn’t find any leaking coolant from the water pump.
Any ideas?? Thanks!!
Josh
Josh
