Power steering box ?
just a little trick to make install easier, thread the new hoses in before you bolt the box to the frame. you can tighten them after it is mounted but those fittings are a PITA off and on.:D
Got the box pulled off tonight... PIA! Actually wasn't to bad except the hose they came loose ok but the nuts where stuck to the tubing and could not get them to turn with out the tubing spinning. Ended up twisting them off , guess she will have new hoses also.
The frame and old bracket are actually in great shape, I think I am still going to order a new hd mount.
The biggest reason I ordered the new borgeson shaft was to get rid of that hokie joint at the steering box. I also think I got a good deal on it, ordered from Amazon and got it for 192.11 with free shipping.
Now to get it shipped out , mr.lee said he was about 7 day turn around right now.
Time for a :chug:
Sounds like a good plan. I have also been reading about inline power steering fluid filters, anybody run them? Do you think they are good to use? They are not that pricey just didn't know if they are really needed.
West Texas off road also specializes in p.s. boxes. You can send them a box to be rebuilt also. They have quality rebuild kits and are helpful. I had a sloppy leaking box. I did some research, ordered a kit from from them and after calling them a couple times with some questions I got it done.
Napa sells rebuild kits as well.:D
Well my new power steering hose showed up on the doorstep today, only problem is they came with no o ring. I think they are the right hose just like they don't come with the o ring. Anyone know the correct size o ring I need? Can't believe they come with out. Thanks
something strange here. the 81 should have o rings both ends on pressure hose. will the male flair come out of the pump? could someone have gotten creative with it??
I got my hoses from Oreilly s auto parts, right the first time. My past experience with JCW is to be amazed you didn't get brake pads for a motorcycle. they never got an order right for me.:D
Well that's what I am thinking.. Maybe not the 81 power steering pump? I have been all over the parts store trying to find a hose that is flare on pump end and o ring on box end with no luck, but the one that was on it ( that I ruined when I took the box off) was that way. So I am thinking I am either down to getting a custom hose put together or replacing the pump with a rebuild one from an 81 cj.Which if I do the later will it bolt right up to my existing brackets, will the existing pulley work on the pump?:confused: any input would be great
Go down to your local junkyard and pull the correct fitting off the back of a donor power steering pump. I had the same problem recently (except that I needed the earlier flare fitting) and just found the correct one to swap. Really easy, millions of 80s era cars and trucks used O-ring style hoses on that same pump. I have my old one here in the toolbox just in case I need it in the future. Really easy.
Thanks bigt... I pulled the one out of mine and got one coming. Knowing is half the battle!
Cool, glad it helped. :)
Talked to Tom at Lee power steering today. They got my box tore apart manga fluxes and everything looks good. It had a 20-1 ratio and he recommended I go with a 16-1 variable ratio to 13-1. He will put it together tomorrow and be headed back to Iowa on Wednesday. Then I will have all the parts.... New hoses, new borgeson steering shaft, new rugged ridge HD mount and cleaned up the steering box brace and repainted it. Can't wait to get it back together and try it out. Now if it would just warm up a little so I want to get it out of the garage. This -3 temps is a bunch of :dung:
:)Sounds good looks like the process is moving forward, let us know how you like it.
:D:D:D:D
im going to be looking at mine..apparently p.o used the PS out of an old AMC car..so the only issue he had was he had to weld the pitman arm i believe...i had a quick look at the bracket holding it and it looked really strong..maybe it already has a H.D mount i dunno
You should be able to tell, the stock mount is very light weight , made out of stamped steel and it is two piece. If you want when I get home tonight I can post a pic of the factory mount.
