Build Thread Project PJ
cerial
Middleville, MI
1969 cj5 Stock right now
The PJ idea was just something that sounded right. The only thing left of the stock CJ will be the frame and part of the firewall so I can hardly call it a CJ.
I have been out since Christmas and am getting a bit tired of writing about this and doing nothing. I have designed a great tank and have all the cage down on paper to be put into the computer. They tossed me another crazy offer centering out of Indianapolis that's once again paid by the day. This one is 7 days a week instead of 6, it should wrap up in about 5 weeks. Pending another "crazy to turn down contract" I will ask for a entire week off when this one expires. Maybe I can get to tearing down this thing and bending some of the tub this year.
Update: Been out since Christmas so no progress on the jeep.
What I have done is get a pile of tools around. Air/hyd bender, notcher, portaband, various, saws and fab tools.
I have streamlined the cage making it so that all the exterior panels can be removed. By doing this I can use uhmwpe instead of hdpe. The uhmwpe sheds water, mud, etc a lot better then the hdpe. The down side is that it only really comes in white and currently there is no way to glue it together like with the hdpe. So, I had to change things around. The benifit would be that it is basically cutting board and any scratches will be a lot less noticeable.
I have also dropped the leafs in favor of a custom tri link(not 3 link) air ride suspension.
But, for right now I am still getting stuff around. I need to order the break system that is a 90 degree system that will hide the breaks under the dash.
In about a month I plan on taking a entire week off of work. Cutting the jeeps tub into shreds leaving the firewall/dash and grill to serve as reference. I will fish plate most of the frame and reinforce the inside leaving the stock drive train in place to serve as a reference. Once the frame is stiffened I can build the inner and outer cage off of it further stiffing it. Hopefully have the interior and most of the exterior skeleton built before I leave.
Originally I was going to have the tire lay down on top of the tank. But after looking at it in max I found that it blocks most of the rear view. So the tire will sit on a slide-able base on a angle behind the driver. This will give a practically un obstructed view out the back. This means I need to have a smaller 15 gallon tank that will be under the tire and behind the driver. That will help a bit with weight distribution while giving me better flex as I will not need to widen the wheel wells to fit the tire.
Really want to work on this but work comes first.
Well it is weird how things work out. I was susposto return 8/1 and tear this thing down to the frame. I had a entire week planned off from 8-1 to 8-6. For the last 2 months I have been on a buying spree. Getting the a protools air/hydro bender, tube notcher, I bought a Millermatic 221, and tons of various tools. Everything to get this down to the frame and start building this Dual cage ready so when I returned I would just need to get some steel and a couple other local items like the seats that made no sense to ship. I have over $3,000 in tools now sitting at the house and well My boss tosses me a contract back on 7/30 that pays 3 times what I normally make and I could not respectively turn it down. It runs for a entire year which means that it will most likely run for a year and a half. But, the chance of me getting a entire week off to work on this while on this contract is not going to happen.
So I have been out a week on this contract and I really regret taking it but guess it is better. I'm out here saving for a house and while I would love to actually start this build instead of just getting parts around and talking and planning.
Couple of things have changed with the extra time. Originally I planned on using the 225 Dauntless Buick 225 V6 but the lack of support in aftermarket parts is just to much for me to see using in this. For the same amount of money as a professional rebuild I can buy a crate motor and so a high torque 383 will sit under the hood. The T-18 will remain the Transmission and at this point I'm still planning on using the dana 18 Transfer Case .
The Toyota axles will remain. But the biggest change is the fuel. The tank is out all together and in its place will reside 4 vertically mounted 20 gallon propane tanks. So the floor once again gets raised. The 35" spare will sit atop of the "floor"as planned with the tank above and will fit with the only rubbing of the rear tires against the inner wheel wells being at crazy angles.
There are tons of reasons for propane cost being the greatest. I am guessing even with the Overdrive this will get around 13 city 18 highway because of the weight. At just over a dollar a gallon for propane(roughly $2 at a high places) and the additional benefits like higher octane rating and efi running angles I would be crazy not to go the path. I am using the 20 gallon tanks over say a 8 gallon tank because of the availability. A 20 gallon (bbq) tank can be found anywhere at any time of the day or night so I will not need to worry about fueling issues. I plan on a rack that is on rails that will slide out the back once unlocked for easy tank exchange. This rack will be between(but above) the frame rails inside the inner cage and inside the outer cage with the tail gate acting as rear protection. It is well protected only second to the driver compartment. I am building this to take a multiple roll without issue and/or a side impact of up to 38 mph at the expense of weight. The ability to turn on/off the tanks as needed so I could run all day while keeping a extra tank in reserve is also another reason I wanted the 4 tanks. With 4 20 gallon tanks filled to the standard 80% for expansion gives me 64 galllons to run around with.
So that's where this project pj sits. I still have a long shopping List but it is more of the drive train 383 stated above., 90 degree under dash double booster with mc, and shock wave air ride suspension. Will be getting them over the next year in prep for when I do finally return. I need to send Herm some emails and see what he can do about a Dana 18. With the gearing of the T-18 and the almost 400lb of torque the stroker will be making the Transfer Case becomes the weak link. I really want to keep the over drive feature. But if I am advised against it by Herm I can go with a atlas. Although the idea of the replacement of high dollar Transfer Case like that in say 10 years does give me a bit of a concern.
Will get more advise and move along in shipping/tossing things into the parts pile. For a while though this project will just collect dust. I'm not a quitter though, Most builds end because of lack of money or interest. I have set aside enough for this build and have planned for years to build a jeep from the complete ground up of my own design and doing. I hate to keep delaying this due to work but the point is staying out so I can buy a house outright and then go local. I will not rush things despite how much I want to play with this project. Good things take time I just need to keep focusing on putting money in the kitty towards buying the house while tossing a bit at this from time to time.
When you are old and grey the last thing you are going to say is "man I wish I did more work for my employer". Just saying.
