    Thank you for your support!
Build Thread Project Rot
This may be a stupid question, but is this my oil pressure sender? 20170227_165335_zps17vfppv4.webp
Sent from my SAMSUNG-SM-G891A using Tapatalk
Yes, sir. That is what it is!
It is indeed. And, no, it's not a stupid question. Doesn't appear to have anything connected to it....
Edit - dontcha love it when you post an answer only to find one went in just before yours..... LOL. Gonna change my username to "Echo" LOL
I was in the process of trying to clean up the wiring some and and if I read my multiple wiring diagrams right the wire that was supposed to be connected to it was hooked up to the alternator. And nothing was hooked up to the sender. Is the wire just supposed to be hooked up with a ring terminal?
Yes one wire to the tip of your oil sending unit
Thanks for the heads up. Is there a better spot to plug in the manual sending unit?
The OEM location on the block is best.
That will probably be one of the easiest things I do then.
Whew - At my age I have learned to never say stuff like that. Murphy follows me around with a stick......
So slightly confused, found my title and it shows my jeep as a 77 but when I decode the vin it comes back as 78. It seems that 77 to 78 was a change over year, how do I tell which on I should go off of as far as service manual etc?
Buy em both?? You may find features from both years...... that'll be fun
No confusion, someone down the line pulling a fast one maybe
