Build Thread Project Scrambled - The Diesel Powered CJ-9?
Have no shame sir! Build what you like , the small diesel is a great idea, I should have done it with the 2.8R Cummins
100% agree 👍 Build it like you want it. I haven't seen a 100% stock CJ since 1972... :chug:
I did today a1982 CJ7 hard top out in the snow . Talked the owner a while back nice guy and were that jeep mine zero mods it is that nice.
This would be a good time to run a couple of spare wires through the frame for possible use later. You may decide to add some rear mounted LED lights for example. You never know when you might change your mind about an idea. It's easy to pull 'em out if they aren't gonna be used.
I love your idea but the one big thing I despise is body work! I just hate it!
I feel yah!
For some reason I find it therapeutic. Where it really gets tedious is the final stages of body filer, block sanding, priming, guide coat, more sanding, etc, etc, etc... I guess it depends on how far you really want to go and what level of perfection you really want. Banging out some sheet metal and leaving it that way for a trail only rig is one thing and easy. Going the distance and putting in many hours and hours and hours of prep, sanding, etc. to make something better than stock is an obsession and in some ways crazy I guess.
