Project YJ
Project YJ
LASTCJ786
Mass
86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
Project YJ 1990's YJ 3:07 gears Dana 30 ,Dana 35
Going to be 4:10 gears Dana 30 , Scout Dana 44 rear.
I cut off the spring pads. a YJ axle is 60" back plate to back plate
a Scout 2 Dana 44 axle is 58" back plate to back plate.
a Yj bolt pattern is 5 on 4 1/2"
a Scout/CJ is 5 on 5 1/2" going to run differnt rims for now.
Pulled the Dana 35 out and put the Dana 44 in on the New 2 1/2 pads
got my angles and measurements side to side and tack welded it and the new shock mounts. Pulled it back out stick welded the pads and shock mounts a little at a time to not put to much heat to it.Used the stock spring pads but made it to fit the Dana 44 U bolts with a torch. Set it all back up again. with the drive shaft shocks etc.
The NEW front Dana 30 with 4:10's was bent waiting for anew one.
i would take the whole front end off and put a cj front end on it to get rid of those headlights lol. just kidding :D
Yeah it's not for me it's for a buddy. I've got the last CJ. lol
