Putting on a Bestop
Putting on a Bestop
ftwflh
Crossville,IL
1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
Is there an easy way to do this by yourself:(
lay it in direct sunlight, or heat it up with a blow dryer
make sure the staps arent tight also can make for a fun install
oh and start at the front and work your way back
Thanks for the directions :chug:
I got it on last week but it did take some help from a friend to get it on right.
I once wrote an essay about putting on the soft top
I do it alone and give myself about an hour to do it
have to let the sun warm it up first, then throw it over
and then get the front set in the window channel real well
and then get one side started
then get the other side started
then finish one side
then start the back and finish the other side
then finish up
and then loosen it all to get the front in the window channel real well
and then tighten every thing up
hopefully the front will stay in the window channel first time it goes down the street
