Random jeep part game
This one may be too easy.
That one is easy for most, but not all, I will leave it for Asphalt to try.
Hint: It's not a brake spoon. :)
And it’s not a pickle fork.:cool:
not close on the first but what kind of cap on the second and where used?
I want to say the disks from a rag joint in a steering shaft but I don't know the size of the disk, diameter?
no, here is a clue, the top one is not flat, it has a small seal on it to retain 90 weight oil
ok the second is a dust/grease cap from an axle, if you are using this, what type of axle is it, flanged, 2 peice, or full floating ?
you got it on the head Cheap
Ok, how about the oil seal and bearing retainer on an AMC20 and the bottom is the cap?
