Rear Axle Relocation
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Hi Guys,
So on my CJ5 , after I've installed this new suspension, I'm still having rubbing issues on the front edge of the rear wheel-wells.
I'm thinking of stretching the rear end.
I know I'll need to do a few things to do it right, and have two options floating in my mind...
1) Hang the rear shackle off the outside of my sturdy bumper (many of you will remember the build - It may as well be an extension of my frame) low enough to allow movement, and possibly add small amount of lift to the rear (the equivalent of longer shackle theory without the longer shackles...) THis will require a custom gas tank build, relocation of the gas fill spout, and rear body trimming. It will move the whole axle back increasing wheel-base, helping stability and helping to prevent topple over on hill climes.
2) I can slightly relocate the actual axle on the springs where they are, probably 1-2" max offset from center of spring towards the rear of the jeep. This would be easier, but is it feasible or frowned upon?
I know there are some easier options, such as buy a CJ7 and swap all my newer parts over, but I'm trying to avoid that at the moment...
So thoughts on my dilemma? Need more info (if I haven't explained problem and proposed solutions good enough, let me know)
For reference, here is the Rear Bumper I "plan" to attach shackle mounts from...
http://www.jeep-cj.com/forums/f49/rear-towing-bumper-info-9082/index3.html#post77467
~ Jr
~ Jr
