rear view mirror
rear view mirror
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
I am about to glue the rear view to the new windshield . This is a bit OCD but I am wondering if there is some standard distance down from the inside of the glass gasket. If a few of you guys happen to be in the vicinity of a CJ with a measuring device. I would love to be able to compile an average measurement. :cool:
The few of us with front roll cage additions that have a cross tube near the windshield, Are you experiencing any conflict with the mirror?:mad:
Silly question, but why not mount it to the roll bar?
Did you go with auto dim, temp and compass? ;)
the roll bar isn't there just yet but that is an idea , I guess.
I had not even thought about a fancy mirror like that. My truck has one of those and it a bit silly even by my standards. I can generally tell direction as well as the compass, knowing the temperature in the CJ would more than likely just depress me and that auto dim thing is a real distraction. When a following car is in just the right position the headlights seem to flash on and off.
I centered mine to the footman, held the mirror foot to the top of frame, attached the glue on piece directly below that. Use tape to mark wher tou need it.
Remember, it needs to slide down onto the bracket.
I was toying with the idea of fabbing a bracket to mount into the footman loop holes. I've seen others rigs with this mod. much better visibility.
Mine is 1 1/4 from top. Different mirrors that could have ended up in yours may require a different minimum spacing from the frame. I have a day/night toggle GM mirror. Not sure if it's the same as a Jeep one.
I'm really bad on cloudy knowing which way north is.
Gotta have some fun. You're a good sport! :D. :chug:
It should 3" from top of mirror knob to the gasket. And be sure to use the right stuff to glue the knob to the glass. Super glue is a nono.
Three inches? from the top? That's seems too low, in practice. I don't dispute that as fact, though.
Judging by the other mirrors placement, and wiper park position. AMC didn't want the driver to be able to see well.
I'm 5'9'' and three inches from the gasket is level with my eyes. Mine is placed higher for this reason. Maybe my YJ seats and brackets are the reason?
If I really get confused I always have the compass in the but of my Rambo knife.:D
So what height did you mount the mirror, IOport?
I have not mounted it yet. To be honest, I am still thinking about the mirror with the compass in it.:D
My mirror mount is cemented at 4 inches from the top seal of the windshield.
FYI GM mirrors require a separate module installed for the temperature, if you get a temp/compass unit from the boneyard.
A few Chevy truck forums have all the info you could want on this subject. Map lights are good, too. Put one in my 91 Step-side some years ago. the windshield mount ones have standard mount as the Jeep.
You're gonna snake the wires through the w/shield frame, right?
Some nuckel head 35 years ago broke mine. Went and got 1 out of a junk yard somewhat similar . I glued the small metal plate 2 inches from the top of the window. I use that to look directly behind me and tilted to right so I can look to the right behind me on the right side. I don’t like the right side mirror position on a CJ. So I only have the 2 mirrors on mine. Two works for me.
I swear there is no glue made today to reliably hold a mirror to the windshield regardless of prep, I went through dozens. I eventually used mirror from a 60's impala for my truck, similar to OP's solution.
I actually searched for an older mirror like that (with a mount designed to bolt to the windshield frame) but I wanted the map lights, and those are only available in newer (relative term) mirrors. I didn't care about even newer ones with a compass or temp reading (I know the temp outside 'cause the top and doors are usually off) but really wanted the lights.
I put new glass in my windshield and chose not to follow this guideline. I felt it put the mirror right where I look to see cars on the right, when I'm at an intersection. In other words, it blocks the view over there. I put it higher, but still on the glass.
I suppose they want it that low so you can see out the back with a hard top? I don't have a hard top, so I'm not sure... but the Bestop soft top that I have has a plenty tall window in the rear.
Just answering the original question.
Brakes 10 or 11
