Replacing T5 with T176
amdavidson
- Delaware
- 1982 CJ-7, 258, T176, D300, D30, AMC20 w/ LSD, 3.31 gears, 31x10.5 ATs
So the T-5 in the new-to-me 1982 CJ7 needs (at least) a input shaft bearing. It whines and grumbles loudly in first, second, third, and fifth gear.
I'm thinking of pulling it and replacing it with a T-176 from Jim at CJ5 .com. Is that a good idea? It seems like the easiest way to get in to a more robust Transmission . I looked at a T-18 swap, but it is more involved with revised shafts and clocking rings to keep the Dana 300 .
So far I've pulled together the following parts list for the swap:
* Used T-176
* Used F&R driveshafts
* Used Bellhousing
* New flywheel (while I'm in there)
* New clutch
* New throwout bearing
* New / revised Transmission tunnel cover and shifter boots.
Is there anything else I'll need?
Is there anything I should watch for in buying a used T-176 ?
* Used T-176
* Used Bellhousing
* New clutch
