Reverse is really shakkkkyyyy
khass0410
Pilot Point, TX.
75 Jeep CJ5, 4.2L Straight 6, Dana 44 & 30? T30 TC? 3 Speed,
So it seems every time I go to back my jeep in the garage as i'm starting to let off the clutch my jeep has the CRAZY shakes so bad that it almost wants to just throw my windshield against the hood. Am I doing something wrong? or is there something I need to replace to make her not shake so much?
My first thought is your clutch plate is worn or has some oil on it, but I'd first check your rear driveshaft yokes and u-joints for wear.
Also your engine mounts and Transmission mount / torque limiter (stud) may be loose or broken.
I am going with the clutch plate. broken damper springs.:cool:
WOW!!!!! :D Thanks guys. Hmmmm it seems that once I fix one problem with her she always has another. Looks like I have some research to do. Not only is this happening but she decided to start throwing and spitting up coolant today ALL over the place ugh :(
Thank y'all I shall start from the very first post and work my way down. :chug:
    Best for votes
    on specific items
