Wiring Right turn signal stopped working
Woo1984CJ7
Charlotte, NC
1984 CJ7 (searching for my old CJ ... VIN 1JCCM87A2ET107246)
1985 CJ7 bought May 2020
Hi all, my right turn signal stopped working. It was working fine, then started giving me issues. Initially when the problem started, the signal would take some time to “warm up” and would work only after a few minutes of engaging it. The driving light function works… but not the turn signal or hazard function. When I turn on hazards… all lights front and back blink except my front right. My left side turn signal works fine. When I try right side signal, the rear right gets brighter and stays bright… front right does nothing and speedometer turn indicator does nothing. I replaced the bulb and had same problem. I then replaced the whole parking lamp assembly, and same problem. I then replaced the flasher and same problem with one slight difference… the flasher makes one cycle sound then stays silent… the front turn signal never flashes and the speedometer indicator never flashes though. I have OEM lighting all around except LED taillights, which I’ve had for a year and the issue only started recently. Any ideas?
Sounds like a ground gremlin. The front lights have a dual filament bulb, one for the marker light and one for the turn signal. So the connector plug has two wires in it. Then they use the housing and the screws mounting it to the grill for the ground (third connection). Very common for that ground connection to be intermittent or fail due to any rust, corrosion, or even paint on the grill surface and in the screw holes. An easy test is to use a short clip lead (wire with alligator clips on each end) to connect the light housing to a known good ground source and see if it works. Another potential issue is the side market light on the front fender. If that is not working, the turn signal won't work either. You mentioned you replaced the front turn signal, but no mention of the side marker light. So a place to check. Just swap with the left side to test.
If all that checks out, you're now looking at the turn signal switch in the column or the wiring. I wouldn't suspect turn signal switch since the rear light tries to work and you get one click of the flasher unit. Seems the actual switch in the column is working. I've seen an issue with the connector plug at the lower part of the steering column where the turn signal wiring comes down the column and then connects into the under dash harness. Also seems less likely since the rear light tries to work by getting brighter. But I've also seen an issue with a corroded or gummed up pin in the bulkhead connector on the firewall under the hood. There you have a specific wire for the front left and a separate one for the front right blinker connections. When I say "gummed up", I've seen some of those pins in the connector stop making connection due to the "goo" that was applied to waterproof those connections and over time it gets like tar from heat and age and coats the pins. You have to remove them and scrub them clean again.
Do both brake lights work?
I agree, it sounds like a grounding issue. I would check the tail light enclosures. The bolt grounding into the body can get loose and rusted.
Oddest thing just happened… I went out to check the lights again. I turned the hazards on and still had same issue with right side not blinking. Then with hazards still on, I turned on headlights and the problem continued. With hazards still on, I turned off the headlights and the blinking sped up slightly but still no blinking on right side. The quicker blinking caught my attention so I turned headlights back on again and ALL lights started blinking like they are supposed to. Hazards and turn signals now all work fine….rear, front driving and front side and speedometer turn indicators. No clue what happened. Maybe ground or flasher gremlin decided to be nice.
That’s not odd. It’s an old Jeep.
Again I would really check those bolts grounding the taillights. It's either that or you need an exorcism. Just get a young priest and an old priest. 😁
FYI, I had issues this past week. No dash lights, then blinkers, then brake lights.
I got a ground block, star washers, and new ground wires. Put a block on firewall, then put star washers under ring crimps.
Then, pulled fuse and looked fine. Last ditch, put a new fuse, and bam, all signals back to great.
Might be a last ditch try, switch new fuses if they look ok but old.
Check out this link, mind you it's comprehensive;
JeepHammer Bible
This being said even our Jeeps of the '70's had many a ground fault. My solution, after reading through the link above was to build a grounding bus bar that I got from a breaker panel at Habitat for Humanity, and using the Mil. Spec. Battery Terminals that I use I ran 6 gauge welding wire from the Negative terminal to it, then tied ALL of my dash and underhood grounds to the bus bar. This once and for all took care of a plethora of electrical issues.
Since they started working again after replacing the fuse, check the connections behind the fuse panel. I've seen those crimps get loose/corroded where the metal prongs that hold the fuses are crimped onto the ends of the wires and then inserted into the plastic fuse block itself. Then when you jiggle them by moving or removing and inserting fuses, weird things start to happen.
Electrical Relays
