Rookie mistake
Rookie mistake
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
I need a little help. I did not take a picture of the sway bar brackets on the frame. And the spring plate that the links hook up to. The brackets have a left and right. On the brackets there is to gussets one smaller the other larger.These gussets go on the inside but I need to figure out witch goes to wards the front. Any help or a picture of the sway bar mounts would save me a whole bunch of trouble. An the links go forward of the shock I presume? Well we learn from our mistakes.
I'll get some in the AM for you if nothing happens before that time.
Its pretty cool that someone would take time out and snap a picture to help out someone that had a brain freeze. I took of the driver passenger tape tag I had on the bracket and then one thing led to another . A left right mix up moves the bracket forward or backwards thus it is important. Once I figure out the whole picture post thing I will be able to post pics to help explain in such cases. Real new to the whole fourm concept once again thanks.
That's what we do here. I've been on the other end myself.:chug:
I have a 83 but I think it would be the same. Here's a couple pics I found
where the sway bar mount got included. Hope they help some.
Here's the passenger side of my 78.
It appears that both jeeps have the angle pointing back I did have it right according to the pictures both you have. You fellows ROCK.
