rubbing
rubbing
arlington tn.
1984 cj7,258 inline 6, dana30 ,amc20,dana 300
i have 2 and half inch lift with 285 tires. i am thinking of doing a SOA lift and running 35 or 36 inch tires. the question is will the 20 and 30 hold up to those tires and will the motor and Transmission be enough. i will be doing moderate off roading and driving around the street any suggestions
The 20 with 1 piece axles and the 30 will hold up IF your easy on the skinny peddle.
35's will rub if you don't do some body trimming (you need to open the wheelwells up to tj flair size)
You will also need 4:56 or 4:88 gears with 35's
$185.00
  92.5%
