Running windshield washer line, do I have to take apart the dash?
cuban11182
CORPUS CHRISTI
84 CJ7: 258, T5, Dana 300, Holley 390, Nutter Bypass.
I'm trying to see if there is an easier way to run the line to the spray head. I know I have to access it from the inside, but looking underneath the A/C and all the wiring I see the ducting for the heat. Do I have to remove the dashpad, or the entire dash to get to it?
Thanks.
Mine just runs across the front of the firewall and goes to sprayers in the cowl vent. I guess yours must be fancier than mine.:D
Mine runs into the cab from a grommet in the firewall. The sprayer in not accessible from the cowl pocket.
Could it be?
can you see the nipple on the spray head? I am thinking about one of the long hemostats from HF.
Pulling the dash bolts and pulling the dash back, even a couple of inches can be a big help. And it is not nearly as much work as it appears. The hard part is dealing with the torx bolts.:cool:
I just fixed mine and the best way is to drop the dash it takes a little time looks worse than it is
washers on a jeep are greatly over rated. They really can't compete with that much dirt.:laugh:
I have laid on the floor and was able to reach under the dash and plug it in but I don't have air and it was a bitch.
