sand blasting
sand blasting
I'm more than likely going to have someone sand blast my frame, hopefully I can have someone come to my house.
After the sand blast what do you recommend to clean whatever sand is left behind? Also, what should one apply after you clean said frame? Do you need primer then POR15 or just sand blast and POR15?
Thank you.
I had a frame sandblasted down to the metal. Just blow off as much of the frame with compresed air. Trust me you dont need any solvents to clean it. If you feel the need use laquer thinner and one of those blue paper towels to wipe it.
You dont need primer with por15 either. That stuff is amazing! Once you brush or spray that stuff on and it dries it will look like you had the frame powder coated.
Make sure you wear gloves. once that stuff hits your skin you will wear it for about 2 weeks.
Hope this helps
$45.00
  22.5%
