Shift indicator
Shift indicator
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
The shifter needs to move to the right (when looking at the picture) so the shifter fits in the middle of the Y, not to the side.
Looks like you got a twin stick there. My Dana 20 LH rail would be the rear axle. I put a 4WD light on the front axle (RH side)
Thanks men I will move it over, Sorry for the bad grammer on the org post but that is what happens when you post late at night and do not double check.
Once I pulled them it was clear that they needed to be changed I should have taken a better picture. Live and learn.
