Should be an easy one?
Hedgehog
Always Off-Roading Jeeper
Tucson/Marana Arizona
Pulling the front body work from the CJ to swap the motor. Noticed there is some sort of rubber like tape, possibly double sided tape, between the main parts. I imagine its there to keep things from ratling and squeaking. I would be good to have some for reassembly. Do you know where to find this stuff?
I got some from napa, Body seam tape.
I also used some plumber's putty on the Transmission cover parts and under the roll bar. It takes up a bit more space, seals the gaps, just wipe off the excess that squeezes out.
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
Body seam tape. I thought it would be something like that, it almost makes too much sense.
